Rear seat question
I have a 2008 Panel and want to install a rear seat will a 2007 fit.
06 thru 11 are same mounting bolt locations, maybe different fabrics and you will need the bin tray just behind the seats from the 07.
Rear seat
Thank you Sir
Plus a way for the passenger to open the door from inside. Don't recall all you'll need but there are some threads about doing this seat install on the panel.
Try the Search function (above) for those threads. |
if you are buying a seat front a junkyard or from a parts car be sure to grab the compartment behind the seat and all of the seatbelt bolts. I made that mistake. When I swapped mine I was surprised to find that all the holes are there and no modification was needed.
| All times are GMT -5. The time now is 10:21 AM. |
