seat cover question
So i have a manual drivers seat with gray interior. I found a power seat with black interior. Will I be able to switch seat covers? Thanks
changing the seat cover isn't difficult. A $100 at a good shop will get it done right. Do you have all the connectors to make the seat work and you might have to reprogram the computer. Also, when you install or remove seats, it is recommended that you disconnect the battery until you are all put together.
