Crazy with paint!
Crazy with paint!
I got sick of the cashmere theme for the HHR so I decided to add black into the mix...
I used krylon fusion spray paint for plastic. Didnt bother with a clear coat since it looks shiny already.
thanks all. Here's are answers to some of the questions:
I used krylon fusion spray paint for plastic. Other than cleaning prior to painting no other prep is involved. Two coats and I was done.
I purchased the cover from wheelskins.com.
Nope, not at all. All you need is a flat head scredriver inserted in the right hand side (vent level) and pry it open. Do a search for socal's radio install and it will show you how to remove the front cover.
im thinking of doing the same area in blue to match exterior along with the strips on the doors...what kinda paint and how did you prep?
I also like the steering wheel cover...makes it look much better than stock steering wheel that is on my 1LT.
ARE THOSE CENTER BEZELS HARD TO REMOVE?
