Chevy HHR Network
-   -   06 2.2 code 128 (https://www.chevyhhr.net/forums/problems-service-repairs-42/06-2-2-code-128-a-33834/)
Vern's Auto Feb 7, 2011 04:51 PM
06 2.2 code 128
I have a 06 2.2 93,000 miles I get a code 128 off and on, might go a month and no code then again might get that code twice a week. I replaced the coolant sensor still comes on. It seems to do it when the outside temp is around 40 to 50. Last summer with the ac on it never came on, started when the temp started to change. Runs fine, good heat, ac works fine, coolant runs about 182 to 192, any ideas??? Thanks
nacademus Feb 7, 2011 05:12 PM
There may be more than 2 sensors.
skyeglen Feb 7, 2011 06:40 PM
Are you refering to the P0128 code? Engine Coolant Temperature (ECT) Below Thermostat Regulating Temperature.
Your t-stat is not closing completely and preventing the coolant from heating up to the required temp in the required time. Replace the t-stat and all will be good. The sensors are not the problem.
It's an easy job but if I recall it's about $300 + at the dealer. The t-stat should be about $30 or so.
skyeglen Feb 7, 2011 06:49 PM
Here is a link for you https://www.chevyhhr.net/forums/problems-service-repairs-42/temp-sensor-problems-31928/
In that thread there is a link to the how to thread for replacing the t-stat.
nacademus Feb 7, 2011 10:01 PM
Well, there you go. lol
Vern's Auto Feb 10, 2011 08:33 AM
Thanks I'll give it a try
Vern's Auto Feb 23, 2011 07:52 AM
Replaced the stadt and that seems to be the problem Thanks
