06' 2.4 won't stay running
Old Feb 23, 2023 | 09:35 AM
Sounds like the ignition related recalls have been performed, and then later, the ignition switch or lock cylinder was replaced again. Check fuses #8 and #10 like donbrew suggested for PK3.
Old Feb 23, 2023 | 09:46 AM
Lurch06's Avatar
I've replaced those fuses just to make sure. I looked on the gm website and put my vin in and it shows all recalls have been done.
Old Feb 23, 2023 | 11:16 AM
Lurch06's Avatar
Originally Posted by donbrew
Did you check on the recall? (link in my sig).
The "EVAP code" is the vent circuit is fried. That is behind the gas tank, you may have fried it or the fuse for it. If it was on before the valve might be bad.
The arc would not mess with the key. The PK3 part was already screwed up. Are you sure you have a good title? Sounds a lot like a stolen car.
Somebody replaced the ignition switch from a junkyard and diddled to make it work instead of doing it right.
I might try doing the new key procedure in your Owner Manual (link in my sig) assuming the door key is the original and your ignition key is the new one.
A GM dealer parts department or a locksmith can match a key to your VIN.
i can't seem to find the key reprogram in owners manual. Probably over looking it
Old Feb 23, 2023 | 11:18 AM
Originally Posted by Oldblue
Try this procedure that fixed the issue that sometimes when you jump start a GM it triggers the security system.
Step 1: Insert key and turn to on. (Not start) The security warning light will be on. Leave in this condition for 10 min, or untill light goes out.
Turn key off
Step 2: Turn to on (not start) the security warning light will be on. Leave in this condition for 10 min or untill light goes out.
Turn Key off
Step 3: Turn to on (not start) the security warning light will be on. Leave in this condition for 10 min or untill the light goes out.
Turn Key off
Step 4: Car will start!!!!!!
And when the key is in the off position, it should be left off for 5 seconds. That's what I'm seeing from a couple of sources.
Old Feb 23, 2023 | 12:39 PM
Lurch06's Avatar
G
I've tired that relearn but the security light never stops flashing. It just hate to buy a key and get it programmed and that not be the problem. I don't have a fob so i did think about getting one of those and programmed to see if it would lock unlock doors and turn alarm on off. Am i correct in think that if the fob works then the security system is ok and that would narrow it down to being the key?
Old Feb 23, 2023 | 01:45 PM
  #26
Somebody in MEXICO defeated all of the anti-theft features. I wonder why? Certainly not because cars don't get stolen there. Maybe someone tried the old screwdriver in the key hole trick. Could be the door was replaced.
Look at pages 2-18 - 2-19 in the 2006 Owner Manual for relearn and 2-16 - 2-18 about PassKey3.
A. go to a GM dealer parts department or a locksmith and compare your keys to the one for your VIN. That will prove which has been replaced.
B. I suspect the reason the hidden lever was tied is because the dummy that replaced the key cylinder couldn't find the pages in the Owner Manual either.
That is the security problem.
The other things are probably because of blown fuses in the under hood fuse box.
We have been assuming that all of the jump starting has been done according to the directions in the Owner Manual. Starting on page 5-33. If not, more damage may have occurred.
I just thought; maybe you could hold the door key on the ignition key slot while using your ignition key,. that might fix the security for a while.
Old Feb 23, 2023 | 05:17 PM
  #27
greg8453's Avatar
Why do you refuse to put a scan tool on it? It will show you in short order what's going on.
Old Feb 23, 2023 | 05:42 PM
  #28
Lonwane's Avatar
This may be a silly question, BUT,
does your key have a little square box with a plus sign (+) in it?
Old Feb 23, 2023 | 05:52 PM
  #29
Post #11 says both keys have the “+” symbol.
Old Feb 23, 2023 | 06:49 PM
  #30
According to post #9, he did and listed CEL codes.
