Chevy HHR Network
-   -   06 hhr 2.2 (https://www.chevyhhr.net/forums/problems-service-repairs-42/06-hhr-2-2-a-67900/)
boatmoter Mar 10, 2026 10:42 AM
06 hhr 2.2
Hi all, have my 06 HHR, auto. 2.2, transmission (just started) shifting hard like I just put a shift kit in it., I serviced the transmission and filter and replace all shift solenoids a little (over a year ago) & used AC Delco Dextron 6 fluid. I just got done checking fluid level and it is perfect. no engine mounts are broke. I also blew out the transmission module by testing it with my scanner while engine was running About 8 months ago, bought one and it was programmed by the vin and sent back plug and play. worked fine. any ideas? I do have a bidirectional scanner, there is no codes
Oldblue Mar 10, 2026 01:00 PM
Check the TCM ground wire, check the ground from the transmission case to the radiator cradle.
double check the pins in the TCM connection.
boatmoter Mar 10, 2026 01:33 PM
Thanks. I will do that tomorrow. morn.
