06 HHR Storage Bin Latch Broken
Hello,
While driving in the pouring rain, I hit a pot hole and the storage bin latch broke completely from the lid.
Anyone else have this issue? I couldn't find a recall according to GM on my VIN.
Front or rear storage area?
Im gunna assume the front. Your not gunna get a recall cause that latch broke. Plus yours is an 06 and well out of warranty.
Check this recent thread out for a creative fix: https://www.chevyhhr.net/forums/show...hlight=storage
Otherwise, you might want to try a salvage yard for the whole door. It's probably pretty cheap as well.
First, there WAS a recall for this specific issue....latch breaking on impact during an accident. I would think impacting a large hole could be the same. GM sent thousands of the repair kits to the owners with instructions to install yourself or make an appointment with a dealer for a no charge install.
You could probably inquire. But frankly, as others have suggested repair it yourself with a salvaged part.
Here read this.....
http://www.automobilemag.com/am/2006...r/recalls.html
Here read this.....
But for only a couple of bucks, mine is much stronger than it was. These nylon screws are designed for tags, so they should last a long time. If not, again, it's cheap.....
On a side note, I did have to remove the recalled part as it's give almost no additional space between it and the lid.
