06 HHR Wheel Hub Replacement Torque
I have a 2006 HHR LT 2.4 Im getting ready to replace the left front wheel hub... What is the torgue on the hub...? Should I torgue any of the other bolts..if so to what..?
1 Attachment(s)
HHR Axle nut 81 ft lbs, & Hub bearing bolts are 85 ft lbs.
edit: Lug nuts 100 ft lbs in increments. |
Does anyone have a chart on what the torque specs should be on the caliper bracket bolts or any of the other bolts that should be torqued down on an hhr?
Originally Posted by West09LT
(Post 723267)
courtesy of a copy/paste from chevymgr's post (easily found via the SEARCH tool at the top of the page - looked for Brake caliper Torque):
•Brake Caliper Bleeder Valve - Front (J41, JL9, JM4)-----11 N•m-- 97 lb in •Brake Caliper Bleeder Valve - Rear (JL9)------------------11 N•m-- 97 lb in •Brake Caliper Bracket Bolt - Front (J41, JM4)-------------115 N•m-- 85 lb ft •Brake Caliper Bracket Bolt - Front (JL9)-------------------130 N•m-- 96 lb ft •Brake Caliper Bracket Bolt - Rear (JL9)--------------------115 N•m-- 85 lb ft •Brake Caliper Guide Pin Bolt - Front (J41, JL9, JM4)-----35 N•m-- 26 lb ft •Brake Caliper Guide Pin Bolt - Rear (JL9)------------------35 N•m-- 26 lb ft •Brake Hose Fitting Bolt - Front and Rear------------------40 N•m-- 30 lb ft Look on your RPO list in the glove box to determine which spec to use. |
