2010 2.2L P0700 P0974 codes, no overdrive, rpms show higher on tach than thru Torque
Old 01-22-2018, 12:59 PM
2010's Avatar
Hi! Having some trouble here
2010 2.2L P0700 P0974 codes, no overdrive, rpms show higher by 200-400 rpm on tachometer than thru Torque monitoring. Also do not have cruise control anymore.
This all started in Texas driving through the last ice freeze storm on the highway.
Cleaned TCM module connections.
Reseated and cleaned grounds for transmission.
Cleaned connections on top of transmission.
Cleaned fusebox connections under hood.
Have not had filter or oil change on transmission, Goodyear says it could use a change, with 160K miles they won't do it.
Also tried disconnecting the battery for 30 mins and reconnecting. Codes still throw, even after reset. P0700 always throws first. It's pending. The P0974 went from pending to stored after some test driving.
Have read through the threads I found on here and it seems to be leaning toward the solenoid.
Can anyone advise differently?
Should I change the oil and filter first to see if it fixes the problem? Added lubegard and the hard shifting quieted down.
First gear and reverse kick a bit when engaging from the shifter. If I shift to L or I it doesn't. Then to drive and we're fine. Still no overdrive. RPMs seem to be causing shift issue/kick from 1-2. 2-3 is smooth. No 3-4. If you get up to 60 mph and let off the gas it seems to shift into OD. Soon as you give gas it goes back to 3rd.
If I have to do the solenoids can anyone post a link or guide to the parts I need and a DIY?
Any advice is better than none at this point.
Trans shop says it's the 1-2 solenoid and they want $700 to fix it.
Help please!
2010 is offline
Old 01-22-2018, 01:38 PM
Welcome to the site, the Problem was addressed here
https://www.chevyhhr.net/forums/prob...0-p0974-56294/
And here
https://www.chevyhhr.net/forums/prob...iod-off-52595/
I’m thinking water in wiring connections, which coulda damaged the Solenoid
Oldblue is offline
Old 01-22-2018, 02:05 PM
2010's Avatar
And here
Thanks. I've reviewed those threads and it seems to be a bit all over the board, except for directly changing the shift solenoids. So your opinion is bite the bullet and get my hands dirty changing the shift solenoids?
2010 is offline
Old 01-22-2018, 03:39 PM
Yep, just the one required, however I’m of the “while you have your hands dirty” train of thought.
Oldblue is offline
Old 01-22-2018, 03:51 PM
2010's Avatar
Thanks oldblue. Should I follow Hanes manual or is there a more detailed walkthrough/parts and tools list available online?
Much appreciated
2010 is offline
Old 01-22-2018, 04:32 PM
The Haynes manual will get you thru it, you might want to watch a couple of YouTube videos to get familiarized
Oldblue is offline
Old 01-22-2018, 06:23 PM
Technical Moderator
It is not a good idea to "flush" the transmission fluid at high mileage, but OK to drain and refill.
donbrew is offline
Old 01-23-2018, 01:17 PM
2010's Avatar
Thanks for this advisement.
2010 is offline
Old 01-23-2018, 07:15 PM
I always drain and fill with a clean new filter, never flush, never.
Oldblue is offline
Vortex421
03-07-2016 09:17 PM
87silver
North East
0
04-10-2011 06:58 PM
Old Ray
Canadian North Pacific
0
03-10-2008 10:50 AM
WickedHHRLT
01-24-2007 11:29 PM
longhorn
11-05-2006 09:53 PM
Quick Reply: 2010 2.2L P0700 P0974 codes, no overdrive, rpms show higher on tach than thru Torque
