08 HHR cold rad cap after driving
Old May 14, 2020 | 11:02 AM
Turner'Nichols Valencia's Avatar
I Am having an issue with my 08 HHR. At first out was a leaky lower radiator hose. Took me some months to get fixed.. Once fixed got the hose and thermostat replaced.(non GM thermostat) because my car was running 🔥. Now i can drive for about 15 minutes and it shoots up to the red! I popped the hood yesterday and the radiator cap was cold but the dash temp says it's running hot... The AC works but the heat doesn't. Could it be my thermostat, water hose, electrical temp sensor or what?...any suggestions?...
Old May 14, 2020 | 11:21 AM
PulpFriction's Avatar
Wut cap now?
Old May 14, 2020 | 11:38 AM
Lonwane's Avatar
The issue lies in the thermostat used. The vehicles are very picky.
Showing HOT but with a cold radiator cap tells me therre is no water circulating through the radiator.
Old May 14, 2020 | 12:03 PM
Yes, that thermostat will cause issues and codes, I recommend an AC Delco 131/158 180 degrees thermostat .
There is air in the cooling system, you have to burp your cooling system to get it out.
Then wait till the code P0128 pops up, it might be a month or two.
https://www.chevyhhr.net/forums/how-...-system-60614/
Old May 14, 2020 | 01:02 PM
I vote a clogged or air locked heater. Maybe a bad water pump. Maybe damage from letting a leak go for months.
T'stats don't usually cause OVERheating.
hwmonkey
Oct 10, 2018 09:07 PM
shojay92
Jan 1, 2018 10:11 PM
Tydog
Jul 27, 2017 08:14 AM
Me and my monkee
Maintenance and Upkeep
13
Jul 19, 2014 06:57 PM
TechnaDriver
Mar 23, 2014 05:21 PM
