144k my first trans delay/slow shift
Old Jul 19, 2023 | 09:54 PM
CT09HHR's Avatar
Originally Posted by donbrew
Is there some reason you can't use GoOgle or call a auto parts store? I guess I could look it up for you, but you have internet access. GoOgle "hhr 2-3 shift solenoid", other search engine would have similar results.
P0757 is actually 2-3 Shift Solenoid valve perfornmance-no third or fourth gear. There is a possibility there are broken or loose wires involved (between the trans and the TCM).
Replace the 2-3 shift solenoid and the 1-2 solenoid. Royal Purple is even more expensive than the recommended Dexron V!, whatever you use it should be a Dexron certified synthetic.
I was confused which one was which, but thanks... On the RP I have a case or 2 in the garage, so less out of pocket money... but I can save it for the Duramax truck and pick up the Valvoline Dex VI at Wally World...
Originally Posted by Oldblue
You’re gonna need the fluid out anyway, I just use Dexron VI .
24207236, same for both, replace them both
You can see the white plastic harness clips, replace them both
Thanks for the help, since it is an involved job, I figured I'd replace all 4 solenoids... Amazon seems to have good prices on GM/AC Delco units and they can be here cheaper and sooner than Rock Auto so I think I will have to go that route. Is the "Pressure Switch Manifold" problematic too? I can't find that on Amazon except for in a couple kits that seem to be generic and/or refurbished so I'd rather stick with new quality brand name parts. Rock Auto has a Rostra one available, but with the same shipping/timeline issue so if that is not a problem prone part I can leave the stock one in there.
Does the factory pan use a good metal with rubber reusable gasket or do I need to find a filter with that included?
I've been scouring through the site trying to find all the info I can...
FWIW, I also have the Service Traction and Service ESC warnings lit up too.
Any chance that these could be related? Should I hold off on tearing into the transmission? The Service Traction and Service ESC lights cam on about a week before the P0757 code and transmission not shifting started.
I ran diagnostic on the car at a friendly shop using their equipment and checked the wheel speed sensors, assuming that one had gone bad causing the Traction/ESC issue but all 4 showed virtually identical speeds while driving.
BUT, the first time the transmission started shifting erratically and throwing the P0757 code was right after I drove away from the shop. I returned to the shop and the owner commanded the B solenoid to cycle a couple times and took it for a test drive and it worked fine for a week, then this morning the code came back and the transmission wouldn't shift out of 2nd on way to Advance Auto, then wouldn't shift out of 1st on the way back home.
I only purchased the HHR about 10,000 miles ago and it seemed to be pretty well maintained and privately owned. It has around 125,000 miles on it now.
Any additional help would be greatly appreciated!!!
THANKS!!!
Old Jul 20, 2023 | 06:35 AM
The OEM transmission pan gasket can be reused once or twice. It is rubber and metal.
Old Jul 20, 2023 | 07:40 AM
There are only TWO solenoids.
The thin rubber gasket that comes with most kits is junk. It the OE gasket is not broken it can be reused.
Do not over tighten the pan bolts!!!!!!!!! that will bend the pan and cause terminal leaking. 106 INCH/Lb, that is finger tight with a 1/4 inch drive.
The traction/ESC is lit because of the trans code. Performance codes turn them off.
Old Jul 20, 2023 | 07:57 AM
CT09HHR's Avatar
Good to hear, thanks!!!
I assume the rubber/nitrile??? Seal for the transmision should be able to be reused as well, as long as I dont gouge or cut it while removing the cover.
I thought most seem to recommend replacing the torque converter solenoid as well as the pressure solenoid while the trans is apart. I have all 4 on the way from Amazon. GM Genuine Parts for the TC and Pressure solenoids and ACDelco Genuine GM Parts for the shift solenoids.
I have an in/lb 1/4 drive torque wrench to use to tighten the pan bolts.
That would be great if fixing the bad solenoid clears the Traction and ESC codes as well!!!! I sure hope it does.
Thanks for the help guys!!!!
Old Jul 20, 2023 | 11:01 AM
If you go to a transmission shop they will want to do a "rebuild", that means replacing the entire valve body and valves and solenoids. Been there, after a few years I now realize it was just 1 solenoid causing the problem. If I knew then what I know now. Amazing what you learn after you turn 60.
Old Jul 20, 2023 | 12:49 PM
  #26
CT09HHR's Avatar
I'm sure!!! We gotta keep learning. Just glad I have some mechanical skills left in the tank so I can do stuff like this on my own...
Resources like this website and people that have posted YouTubeYouTubeake.a huge difference, in many cases $1000s of differences!!!
Old Jul 20, 2023 | 04:15 PM
  #27
I just assisted the_shmoo replace shift solenoids in his 2006 2LT , we did it on jack stands with a floor jack to lower the transmission, tedious but not impossible. The side pan gasket is reusable as was the filter seal .
while you’re changing the filter inspect the fluid transfer pipes for cracking at the welds by the flanges.
Gearhead1
Feb 20, 2022 06:23 PM
Daves06HHR
Drivetrain (Excluding Engine)
7
Mar 2, 2017 12:17 PM
skyline26
Aug 28, 2012 05:08 AM
Talvanos
2.2L Performance Tech
15
Feb 7, 2010 10:02 AM
Unclesams_SS
Jun 7, 2008 11:14 PM
