2.2 liter engine overheating please help
Old Jul 24, 2013 | 08:17 PM
2smokey's Avatar
I noticed my cooling system mode has been coming on lately and now I turned on the heat full blast and no heat is coming out. Has my thermostat gone bad? please help I need to get this fixed tonight
Old Jul 24, 2013 | 08:37 PM
badassbowtie's Avatar
Check the coolant level first...If its low, you may not have any coolant reaching the heater core
Old Jul 24, 2013 | 08:41 PM
Could be a stuck thermostat, could be out of coolant, so check your coolant level as step #1.
If the coolant is low, or the recovery bottle is empty, your losing it or using it. Look for obvious leaks under the vehicle, check your oil, if it looks like chocolate milk....you have an internal leak like a cracked head or blown head gasket.
Since you asked about the thermostat, here's a "How To" thread on replacing it.(2.2, 2.4, 2.0 engines).
https://www.chevyhhr.net/forums/how-tutorial-library-21/how-save-%24350-00-thermostat-replacement-2-4l-p0128-24493/
Welcome to the forum.
Old Jul 24, 2013 | 09:32 PM
2smokey's Avatar
Acouple days ago it was low on coolant so i added more.i checked it this time and its fine.thats why im thinking the thermo is stuck open.heat wont blow hot now either
Old Jul 24, 2013 | 09:47 PM
prod's Avatar
If it was low before, you need to find out why. There may be air bubbles in the system now still causing trouble too.
Old Jul 24, 2013 | 10:10 PM
If the bottle was empty, you better check under the pressure cap. Be sure the hose is full. If the t-stat was stuck open you would get a CEL.
BeExcited 2
16
Sep 18, 2013 09:42 PM
frenchyforet
Jan 13, 2013 03:48 PM
Old Ray
Oct 31, 2007 11:43 PM
shugga
Dec 13, 2005 08:05 PM
