2006 Chevy HHR
Old Jul 17, 2024 | 10:05 PM
Ken Tollefsrud's Avatar
2006 Chevy HHR
I have a 2006 Chevy HHR that will not start. Prior to getting it into my garage and it not turning over again, I was driving it fine. I turned it off to run into AutoZone and when I came back out, I started the HHR, and then noticed i could not get it to go over 20 mph, without lifting my foot of gas then placing it on gas....like a "manual shifting". It barely went over 45 mph, so i was using city streets to get it home. I was lucky to get it into the garage, but then from that point on, it will not turn over. Does this sound like a transmission issue?
Old Jul 17, 2024 | 10:13 PM
No. Is there a pretty CheckEngineLight on the dashboard? Do you ne4an the starter turns the engine but the engine does not start?
Old Jul 17, 2024 | 10:29 PM
When I put key and turn initially, the lights come on like usual, but none stay on, when I turn key there is nothing, no trying to turn, just like a click- type sound
Old Jul 18, 2024 | 06:47 AM
Sounds like the 4 bolts in the under hood fuse panel need tightening! Gorilla tight!
Old Jul 18, 2024 | 08:29 AM
Eman6213's Avatar
Kinda sounds like maybe your starter went... Had the same issue with an Impala I had. Started it up fine and went to the store. When I came out, wouldn't turn over and just made a clicking sound...
Old Jul 18, 2024 | 09:51 AM
greg8453's Avatar
Battery?
Old Jul 18, 2024 | 10:42 AM
Have you been ignoring a CEL? Do you mean the headlights come on then go out? What is the battery voltage, at the battery and at the fuse box? All fuses in both fuse box seated?
the_franchise_18
Sep 14, 2016 07:29 AM
mudbilly
Sep 19, 2011 09:14 PM
deerman
Mid Central
Oct 18, 2006 11:58 AM
SIHHR
Dec 31, 2005 11:19 PM
