2006 HHR climate control panel ...
on my HHR, recently the nighttime, back lighting on the climate control panel has begun to flicker.....only this panel...all other back lighting is fine. already pulled the panel and checked the plugins for anything loose....nothing. the panels heat/ac functions are working fine, ....just the back lighting. any ideas..??......downstream wiring, i would suspect......anyone else have this kind of problem with the modular panel, its
elf..??
elf..??
All of the instrument backlights are on the same circuit. However, the AC control panel is on a separate wire from the BCM. Any recent wire tapping going on? If not probably an internal connection.
Fixed.....
pulled the control panel today...........checked the gray/black(lamp power/ground) leads on the central modular plug on the back of the unit. pulled the connector and cleaned the contacts with contact spray...
Howard M
Jun 9, 2016 02:41 PM
