2006 hhr no 5v key resistor signal at ignition switch
Old Apr 14, 2024 | 05:30 PM
Is the run/crank relay functioning? I think 5v ref comes from the ECM which is not powered until the run/crank relay energizes. Which then brings the PNP into question.
Has the butyl patch been addressed on this car? Look under the windshield cowl on the passenger side, if there is a gaping hole there it needs to be sealed and the BCM and blower/resistor are in question from water damage. To calm any other reader; this advice applies to 2006 models ONLY.
Old May 6, 2024 | 11:42 AM
Wctx's Avatar
Originally Posted by donbrew
The problem is NOT in the ignition switch; put it back together and stop messing with it. The #! thing to do is pretend to be a giant gorilla and tighten those 4 bolts inside the underhood fuse box; probably a good idea to disassemble it and inspect the contacts, then tighten until it clicks a few times.
Only 2 wires on the ignition switch matter for the starter; the wht/blk and the wht. wht/blk is 5v ref and wht is run/crank
Post whatever diagram you are using, then I can have a look. I don't know which yellow wire you mean. You might mean the one that comes from the park/neutral switch on the trans; it supplies 12 v to the crank relay. Or, the one from the ECM that controls the ground side of the same relay.
here is a pdf of the diagram I'm looking at:
Attachment 49448
so I have tested the wire through the pnp switch to the relay and the the dark green wire that runs to the ecm. I have power on the green wire at the ecm. Is there a way to test the 2 brown communication wires from the ecm to the bcm without a oscilloscope. I'm not sure the 2 modules are communicating.
Old May 6, 2024 | 01:18 PM
If they are not communicating there would be a code.
Old May 6, 2024 | 03:08 PM
Wctx's Avatar
I've scanned for codes and didn't have any
Old May 7, 2024 | 08:28 AM
The computer network is a daisy chain kind of thing; if one module drops out every module after it goes dark.
Old May 7, 2024 | 08:39 AM
  #26
Re re check the BCM fuses #8 and #10, Check both sides of them for voltage.
However, I believe the problem lives inside the under hood fuse box or shorted wires.
Old May 7, 2024 | 09:03 AM
  #27
Wctx's Avatar
I also noticed there's no voltage at the 10 amp fuses for the high and low beams. There's about 4 or 5 10 amp fuses in that one spot and none of them have power
Old May 7, 2024 | 09:23 AM
  #28
Wctx's Avatar
What would be a good scan tool that would help me diagnose this problem easier if there is one
Old May 7, 2024 | 09:24 AM
  #29
Wctx's Avatar
maybe in the 200 to 500 range
Old May 7, 2024 | 11:17 AM
  #30
I don't see that you have tightened the bolts yet.
