2006 HHR with Traction Control light on
Old Apr 25, 2014 | 11:26 AM
gcarrington's Avatar
Hello all,
I'm new here. I want to say hello and possibly find out how to fix the problem on my 2006 HHR with 164,000 miles. For the last week or two the T/C light comes on which causes the automatic tanny to shift hard. Ocassionally the check engine light comes on as well. When it sits for a while and I start it back up both lights stay off, but one or both come back on. I pulled code P0011, which is for the camshaft position timing sensor (the front on). I replaced that sensor last weekend, but the lights are stilll coming on. I hear this is a common problem on HHR's. I would appreciate any help on this as I really don't want to take it in for repair.
G.C.
Old Apr 25, 2014 | 11:54 AM
You replaced the sensor? Well, that was the wrong thing to replace - you need to replace the CAMSHAFT ACTUATOR POSITION SOLENOID for the INTAKE side.
That code of P0011 does not point to the sensor. Head over and read this: https://www.chevyhhr.net/forums/how-tutorial-library-21/camshaft-position-actuator-solenoid-valve-replacement-w-pics-p0010-11-p0013-14-a-28779/ It's an easy job to repair it.
(FYI: thread moved to a more appropriate section)
Welcome :)
Old Apr 25, 2014 | 12:45 PM
Lucky's Avatar
Welcome to the site I agree you need to replace the actuator not the sensor.
The intake actuator is marked here in blue.
purple people eater
Sep 17, 2016 01:07 PM
tubejock
Drivetrain (Excluding Engine)
18
Dec 18, 2015 11:08 AM
tmjackson
Apr 23, 2014 08:27 PM
bobnj
Jun 13, 2013 05:17 PM
lorira
Jun 17, 2011 04:22 AM
