2007 hhr new head
Old Aug 23, 2015 | 03:24 PM
Gas's Avatar
Gas
Intake
<br>
Crank
<br>
Exhaust
Old Aug 23, 2015 | 04:03 PM
Printing from undefined.pdfSee if this helps, watch your PMs you might get a surprise.
File Type: pdf
Old Aug 23, 2015 | 04:09 PM
Hard to tell from those pictures. (Can't make out the different color links )
Unless it's the angle of the pictures or a photo illusion, 1 thing stands out.
Exhaust seems to be a tooth off.
Old Aug 23, 2015 | 05:14 PM
Gas's Avatar
Gas
Intake is yellow exhaust is black so is cam. All was set according to all data print out from dealer.
Old Aug 23, 2015 | 05:16 PM
Check your Private Messages!
Old Aug 23, 2015 | 05:17 PM
Gas's Avatar
Gas
Exhaust is off slightly would that cause it to stop at a 1/4 turn when intake is tightened to spec. As it spins freely until I tighten intake my next plan was to mic the intake cam lobes.
Old Aug 23, 2015 | 05:45 PM
No offense, but if it's "off slightly" then it's not timed correctly. Fix that problem first before doing anything else.
Old Aug 23, 2015 | 05:51 PM
Gas's Avatar
Gas
No offense taken its the first thing to do tomorrow after work
Old Aug 23, 2015 | 06:57 PM
The exhaust does appear to be off, the crank sprocket chain mark at 5 o'clock
Old Aug 23, 2015 | 07:31 PM
I'm done.
