2007 lt 2.4 no crank
Had the battery checked, it passed, along with alternator both passed. Put key in, everything lights up normal, turn key to start, NOTHING. Car isnt even trying to start. I will check tomorrow to find out if ignition switch recall was ever done, could be possible cause right?
Any other insight would be great! I know there are other threads about this problem but after reading and reading I never really did find the FIX.....
Thanks in advance!
Thanks in advance!
Hmmmm, I will for sure check that in the morning. I ended up leaving the car at the auto parts store where I was ordering the exhaust camshaft solenoid, get the pesky check engine and traction control lights off. I just bought this car last week and so far its in pretty good shape, just little things here and there, until this no crank problem. I just hope its something simple like this connection is loose....I will keep the forum posted. Anyone else got anything , PLEASE share ;-)
P0014 Chevrolet Exhaust Camshaft Position System Performance OBDII Engine Light Trouble Code | Engine-Codes.com
You may have done a search here , but I posted this for you just in case
