Chevy HHR Network
-   -   2007 lt 2.4 no crank (https://www.chevyhhr.net/forums/problems-service-repairs-42/2007-lt-2-4-no-crank-54765/)
dudeasif Oct 18, 2015 07:26 PM
Had the battery checked, it passed, along with alternator both passed. Put key in, everything lights up normal, turn key to start, NOTHING. Car isnt even trying to start. I will check tomorrow to find out if ignition switch recall was ever done, could be possible cause right?
Any other insight would be great! I know there are other threads about this problem but after reading and reading I never really did find the FIX.....
Thanks in advance!
Lucky Oct 18, 2015 08:20 PM
1 Attachment(s)
There are a few things to check.
First check the battery connection to the under hood fuse box.
This connection is known to loosen up over time and it will cause a no crank condition.
dudeasif Oct 18, 2015 09:33 PM
Hmmmm, I will for sure check that in the morning. I ended up leaving the car at the auto parts store where I was ordering the exhaust camshaft solenoid, get the pesky check engine and traction control lights off. I just bought this car last week and so far its in pretty good shape, just little things here and there, until this no crank problem. I just hope its something simple like this connection is loose....I will keep the forum posted. Anyone else got anything , PLEASE share ;-)
firemangeorge Oct 18, 2015 10:05 PM
Just a FYI. It's probably nothing to do with the ignition recall. A no start issue was not one of the problems related to that recall.
whopper Oct 18, 2015 10:46 PM
x2 on the ignition switch not being at fault.
What was the code from the CEL you had?
Oldblue Oct 18, 2015 11:12 PM
After you confirm the codes , double check the ground wires they are known to shake loose also both under the hood and in the battery area
dudeasif Oct 19, 2015 07:11 AM
P0014 was the code I currently have
Oldblue Oct 19, 2015 07:28 AM
P0014 Chevrolet Exhaust Camshaft Position System Performance OBDII Engine Light Trouble Code | Engine-Codes.com
You may have done a search here , but I posted this for you just in case
dudeasif Oct 19, 2015 09:27 AM
But that code wouldn't stop the car from cranking ?
whopper Oct 19, 2015 09:37 AM
No, it would not stop it from cranking. You are looking at two unrelated problems. Check out those power connections and grounds as above for the no-start.
