2008 body control module
Old Oct 17, 2021 | 04:16 PM
SteddyTeddy's Avatar
2008 Electric door locks stopped working
Woke up this morning to a totally dead battery. I pulled it and put it on charge thinking the FL heat may have killed another one. After a couple hours it came back to a full charge. I reinstalled it and in doing so all the doors locked. I then found the doors would not open with the remote. They also will not work with the switches and will not lock when putting the vehicle in gear(auto trans). I can hear a relay clicking in the fuse area but nothing happens. If I pull the door lock fuse, when installing it back all the doors will lock. All the other anti theft stuff works. Thinking I have a bad control module??? Any help welcome before I take it in.
Old Oct 17, 2021 | 04:27 PM
2008 requires the RCDLR to be reflashed after a dead battery situation
Old Oct 17, 2021 | 04:36 PM
Do the TPM positions work? Try to reset the positions using the procedure in the Owner Manual. Don't have one, see my sig. If you can't then your RCDLR needs to get updated firmware per a TSB 08-03-16-001B for 2008 models.
Or the battery just isn't any good. Dead battery will cause the doors to lock, the ignition to lock, the security light.
First, find out what drained the battery. What criteria are you using to determine "full charge"? How old is the battery?
Old Oct 17, 2021 | 04:41 PM
My charger has a full charge gauge and shuts down when battery is fully charged. Not sure what drained it in the first place. Car starts and drives. Electric door locks just not working now. Yes the tire pressure monitors are all still working.
Old Oct 17, 2021 | 06:14 PM
Have the battery load tested. Chargers are not very smart.
Old Oct 18, 2021 | 08:29 AM
Battery is 100% dead again this morning. Even if its a bad battery, doesn't explain why the door looks weren't working while I had the car running and was driving it.
Old Oct 18, 2021 | 01:19 PM
The need to reflash the RCDLR does, the 2008 model year are just finicky that way.
Old Oct 18, 2021 | 02:53 PM
Dropped it off at the dealer today. I ride with the 2 head mechanics there and explained what was happening. Funny thing is it started to work intermittently as the car was pulled up into the service lane.
Old Oct 18, 2021 | 03:26 PM
The fear of mechanical work! Cold wrenches, brr my HHR has that same phobia!
Is it working now ?
Old Oct 20, 2021 | 12:08 PM
2nd full day at the dealer. They are talking with GM tech support. Hopefully will know more later today.
