2008 hhr ac compressor
Driving yesterday on the expressway with ac on had no issues, then outa the blue it started blowing cool not cold. Then just blew like the vent was on, the ac compressor is new from August last year and pressure switch was new also, anyone have a idea why the compressor won't run, clutch spins by hand and if I put a gauge on it it shoots to the red and will not take any freon please help!!!
Sounds like it's overcharged
Check engine light?
Originally Posted by rj_rs_ss_350
(Post 868809)
sounds like it's overcharged
2008 hhr
Good morning group, there is no ck engine light on, and I pulled the cap on the low pressure side to release any freon if over charged. All I got out seemed like cool air and then the uv green I put my gauge and bottle on and it was reading in the green, I added a few pulls of the trigger and then it shot up just before red, no luck compressor still would not kick on, all fuses and relays are good( I swape them out) what baffles me is this compressor is brand new from Aug last year and has been working fine, any more ideas you might think of?
Some problems set codes, that turn off the AC . Perhaps it’s a pending code, say P0128.
even though there is no check engine light, if you have a code reader or have to go to a local parts palace. Have the codes read and post them here. |
I have been to the autoparts store, and they've scanned my computer. The only code that showed up was a history code for my o2 sensor, they guy at autozone really couldn't give me any ideas why it would just stop working
I am not an AC guy.
How does one check/fill the freon without the compressor running? I don't see any mention of troubleshooting the electric clutch. When the compressor was replaced was the complete system flushed or (hopefully) replaced. If the old compressor blew up it left lots of crap behind. What about the AC diode #9 underhood? |
Originally Posted by donbrew
(Post 868849)
I am not an AC guy.
(Post 868849)
I am not an AC guy.
How does one check/fill the freon without the compressor running? |
| All times are GMT -5. The time now is 04:54 AM. |
