If you cover it with Por 15 won't that block the drain holes?
And I did not mean this in a sarcastic way or anything, I'm serious. Wouldn't it cover up the drain holes when you spray it on? |
I haven't seen a car rusted in many years. Doesn't the GM warranty cover rust for a specific period?
Originally Posted by jerSSey HHR
(Post 477111)
Thanks for the POR-15 tip guys! While I'm going to wait at least another year on fixing the HHR doors, my Trailblazer has the same issue on 3 doors. I've done it once, but it came back.
I was able to check a new HHR out in the showroom today and examined the seams closely. I did not see any indications of either poorly placed or inadequate amounts of sealant and paint coverage was very good. This does not eliminate the possibility of corrosion from within though if there was contaminates at the folded seam. As long as it did not void the warranty, I don't see any reason why you could not use a thin, creeping rust proofing product which would not plug any drain holes. Seams like being proactive here would possibly save you paint & repair labor bills later.
Motoretro |
Originally Posted by CrazyCarKid
(Post 477095)
If It were me, I'd have the door panels off, & paint the inside first.. Rust is curable....Just needs treatment.. |
(Post 477095)
And I did not mean this in a sarcastic way or anything, I'm serious. Wouldn't it cover up the drain holes when you spray it on? You would just take a foam brush and brush a thin coat on, Also the HHR has large drain holes so covering them would not be easy with this coating as it is not that thick. |
Originally Posted by motoretro
(Post 477154)
Motoretro The problem is not on the inside it is in the folded seam and gets under the paint surface on the out side of the door. That it is not a fast rust and would take a while to do any major damage. But it time it would be damaged. The way the HHR door is it makes it easy to see since we have a large lower door. The issue is to get the rust in the folded seam. Not an easy task. I wax the seam and dry it at every was and it still did it on only two doors. |
I just had my 08 and my fathers 07 repaired under warranty. To my suprise they removed the doors and used a tool to unbend the lip of the door cleaned the rust and repainted/resealed the door. It seems that the dealer are doing there best to corect the rust problem.
Oh, I guess I thought it was a spray... I've never seen it before, but that makes more sense then. I suppose I should really look at trying to fix mine...
