2009 cruise control problem
Old Jul 7, 2013 | 11:35 AM
dkitch's Avatar
engage cruise light on switch comes on but does not engage or lite up om dash
Old Jul 7, 2013 | 11:39 AM
skyline26's Avatar
are you also pushing the "set" button to set the speed?
Lucky's Avatar
I would check for codes. Some trouble code will disable the cruise control.
Old Jul 7, 2013 | 12:13 PM
dkitch's Avatar
thank you for your response there isn't a code on the dash but i will have the codes checked
I would check your brake lights.
Old Jul 7, 2013 | 03:31 PM
As donbrew says, check your brakelight bulbs. Especially the 3rd taillight. The cruise control power circuit relays through these.
Fwiw. The brake lights have to be illuminated at least once, each time the vehicle is started, before the cruise system can be engaged and operated.
( I found this out after cussing at the cruise for not working.)
Old Jul 7, 2013 | 05:43 PM
How did you get it into gear without the brake on?
And there is an entirely technical argument with the wording "relays through", but close enough for ObamaWork.
Old Jul 7, 2013 | 05:47 PM
There will never be a code on the dash, only a Check Engine Light. OBDII needs a scanner to get codes, not like the before 1998 cars.
Old Jul 7, 2013 | 06:45 PM
5 speed donbrew. Parked in a flat parking lot beside a country highway. Hit the road( never touched the brakes), 16 miles of road and no traffic lights.
And no cruise cuz I didn't hit the brakes the whole way.
"Relays through" is my generic, "you know what I mean" term.
Old Jul 11, 2013 | 10:20 PM
Forgot your 5-speed.
Purely technical,not worth it except for when somebody decides to take you literally, just wanted to muddy some more water.
