2009 Getrag F23 - no reverse lights
Is there information available on where the switch is located and if it’s able to DIY? I removed the bulb from the reverse light housing and tested it on the rear side marker and it works, but when the car is on and in reverse, the rear lights for it do not work. Thank you.
From the link to free repair manuals in donbrew's signature
https://charm.li/Chevy%20Truck/2009/...Lamp%20Switch/
Do you guys happen to know if at night; when unlocking with the remote; are the reverse lights turned on for extra light? Other GM vehicles I’ve seen do this but unsure on the HHR. Thank you all for the great help and quick responses. I will do all this when I can tomorrow.
