2010 2.4 rough idle when warmed up
2010 HHR No codes. engine idles rough going up and down only in Park or neutral once it gets warmed up. Once its warm above 170 it acts up. Drives fine and idles ok though.
Cold its fine and idles. New throttle body in April. Anyone had this issue?
When the engine is cold, it's running a "canned" program that operates in open loop. In other words, there is no feedback to the computer that adjusts engine parameters.
Once it warms up, the computer now controls the engine based on feedback from sensors. The computer is likely getting bad info from a sensor.
Is there a check engine light? If not, you may have to look at sensor output in real time using a scanner and look for erratic data.
Steve
Steve
It ended up being the MAF sensor and I had a cracked PCV hose coming from the valve cover. I unplugged the MAF sensor and it ran fine. I had replaced it in August and it ' s a GM part. Anyways all set! Thanks for the input, sorry I didn't respond quicker!
