2010 front end shudder
Just drove my buddy's 2010 and the car shudders with vibration right through the steering wheel when accelerating in the 40 MPH range,and also when braking. OK when just cruising. Any ideas where to start? Thanks.
Hubs, rear lower control arm bushings (LCA), tire balance , brake rotors rusty?, rear brakes adjusted correctly.
That's a start. |
Originally Posted by Oldblue
(Post 828624)
That's a start. |
Usually, at that mileage, look at the rear LCA bushings, possibly ball joints, definitely rear brakes.
(Post 828626)
Good start, don't bother with fancy drilled and or grooved rotors, they can cause pulsation in the brake pedal
I had the brake shudder as well. Started by adjusting rear brakes and that cleared 80% of the shudder. Front brakes needed replacing, rotors and pads.
Still had slight shudder and ignored it for a while. Then say bar bushing wore out so I did swaybar bushing, end links. Much better. Next day did the LCA bushings. They were ok but bought them and saw on a video how easy they were to replace, so I did. Factory ones were not solid, had hollow pockets, or what ever you call them. New ones are solid rubber. This eliminated all shudder and all front end movement. Used to feel it slowing down. So, rear brakes first, then check front, then LCA is the way I will go from now on. |
Originally Posted by peterdulux
(Post 830245)
Thank you for the update, enjoy the ride!
