need help
need help
Hi I have a 2010 chevy hhr the Catalytic Converter pipe cracked at the manifold car ran fine but loud I replaced pipe with a new gm pipe on road test check engine light came on po171 and p0300 lean fuel and miss fire runs real ruff black smoke ou the exhaust check for vacuum leaks could not find any I replaced the down stream 02 sensor same then replaced spark plugs same cleaned grounds removed pipe after new cat same anybody have this problem
