2010 hhr lt trouble code po302 and p0300
I just left it a the dealer
I did swap coil , and just so everyone knows , the firing sequence is (1342) i found that out the hard way and after talking to a main tech because every forum and people at the dealer said it was (1234) and its not. I will see what the say after doing another diag and let everyone know whats going on , it seems a lot of people have the same issues with there abs - ecs lights also coming on with this same issue. I will be intouch to let everyone know whats up. Thanks
Here's the facts: p0300 means random misfire, p0302 means cylinder #2 misfire. If you have a consistent misfire in any one cylinder, the computer interprets a "random" misfire.
So, if the only cylinder that is misfiring, after a coil swap and plug change is #2 (the one next to #1 at the front of the engine) it's not really a random misfire.
The problem is in cylinder #2 (period). QED.
If you had a bunch of other codes also I would be thinking electrical connections.
But, in this case I am betting something more serious like; burned valve, leaking head gasket, bad injector etc. Thus, the compression and leakdown suggestion.
Never hurts to check the simple stuff! But don't put blinders on.
Got it
So, i am just going to have the compression and leak down test done because it sounds like a lot of people have the same problem and i really dont think its the connector and if the test comes back that the engine is sound , at least i can rule out any power train issues and not worry about the warranty issue anymore, and that is worth $180.00 to me. I will let you all know what happens
