2010 Rain related water leak on passenger side floor
Old Jul 30, 2023 | 11:14 AM
BobQ's Avatar
I've seen a lot of posts for problems with the 2006-07 models leaky water deflector but can't seem to find anything on the later models, mine is a 2010. It's definitely rain related. It rained hard here last night and the passenger side floor is drenched. I need to replace the blower motor resister but don't want to do it until I've solved the water leak. I'm about to remove the cowl and investigate. Any feedback would be greatly appreciated.
Old Jul 30, 2023 | 11:40 AM
Windshield seal.
Sunroof seal or drains.
Door wiring pass-thru grommet.
Door weatherstrip.
Old Jul 30, 2023 | 02:25 PM
Did the fan start running on high ONLY; that indicates a bad resistor.
AC drain clogged. The AC runs in defrost mode with no warning light.
Old Jul 30, 2023 | 02:27 PM
Leaf or other debris built up in the cowl area.
Old Jul 30, 2023 | 03:43 PM
BobQ's Avatar
After pulling off the cowl, the drain on the passenger side was completely clogged (the driver's side was getting there), the oval drain was partially plugged, and the seal around the AC drain tube was deteriorating. Cleaned out the debris and sealed around the drain tube.
Old Jul 31, 2023 | 07:31 AM
I had completely forgotten those drains!
Verner
Oct 6, 2021 09:33 AM
CruzHHR
Sep 29, 2013 09:27 AM
HHR911
Jan 26, 2013 07:47 PM
billbeam
Oct 6, 2008 06:08 PM
killjoy
May 11, 2006 10:49 AM
