Chevy HHR Network
-   -   2011 HHR Timing Chain and code P0300 (https://www.chevyhhr.net/forums/problems-service-repairs-42/2011-hhr-timing-chain-code-p0300-62006/)
UserK3792 Jul 18, 2019 10:11 AM
Have been working on this for a few months now. My 2011 HHR 2.2LT has had new timing chain, sprockets, bolts, water pump, coils, injectors, MAF sensor, Cam sensor, gaskets, you name it done. It is still running great at 50 to 55 not a miss but as soon as you stop it won't idle. It stalls, jumps, and dies. What suggestions can you offer? Thank you. P0300 is the only code. It also has check engine light that says service ESC and Traction Control.
donbrew Jul 18, 2019 10:18 AM
I would check the MAF connector, then do a compression test.
UserK3792 Jul 18, 2019 10:21 AM
Did compression test and changed MAF twice. Checked the conections. Thank you.
UserK3792 Jul 18, 2019 10:37 AM
Have checked all that everything is okay there.
UserK3792 Jul 18, 2019 10:47 AM
Did the compression test and cleaned the MAF connector and no change.
donbrew Jul 18, 2019 10:57 AM
Compression test does not fix anything, it is supposed to supply information.
The misfire is the cause of the ESC and TC messages.
donbrew Jul 18, 2019 11:12 AM
The numbers are a secret? I'm getting tired of pulling teeth , now.
Oldblue Jul 18, 2019 02:13 PM
You don’t mention changing the cam VVT solenoids . Did you ? Replace them?
RJ_RS_SS_350 Jul 18, 2019 03:11 PM
Maybe test the fuel pressure
UserK3792 Jul 18, 2019 09:25 PM
changed cam vvt solenoids checked fuel pressure 60 lbs and Compression pressure was 150-154 in each injector
