INaband |
09-02-2012 08:26 AM |
2nd water leak solved after butyl patch.
On the TSB I ended up doing the hinge baffle kidney plug area. I had foam
blocking the path to let water drain thru the rocker. After cutting most of that
foam I poured a cup of water to test water flow. We had the rain from Issac move through last night..no leak! I knew water wasnt coming thru the butyl patch repair, and I checked the door water deflector, mirror etc. I also sealed the kidney plug w/ silicon..so far-so good..:D
