ABS Light On
Old Apr 22, 2011 | 01:00 PM
B1GP1MP1N's Avatar
Thumbs down ABS Light On
My ABS light just came on when I parked at lunch. It is now staying on all the time. Anyone have any ideas or have this issue in the past?
Old Apr 22, 2011 | 02:09 PM
Doc brown's Avatar
Bad ABS sensors seem to be common. Usually its a front one. The only way to know for sure is to have the codes read by a dealer. These can't be read by AutoZone because these are not OBCII emissions codes. If it is a bad sensor, the wheel hub has to be replaced, not just the sensor because the sensor is part of the hub assembly. I just changed one due to a similar problem, except mine was intermittent. Quite honestly I took a guess as to which hub it was and I was right.
Old Apr 22, 2011 | 02:49 PM
gcsd3742's Avatar
Unplug the bulb.....RUT ROH, did you do a Diagnostic scan
Old Apr 22, 2011 | 02:56 PM
B1GP1MP1N's Avatar
I haven't had anyone plug it in yet. Have to make an appointment at a dealership to have a Diagnostic check.
If it is a bad sensor and needs a hub replacement, how expensive and how difficult to replace?
Old Apr 25, 2011 | 08:20 AM
B1GP1MP1N's Avatar
Well, whatever the problem was it has corrected itself. The light is no longer on and I attempted to lock the wheels up and the ABS kicked in so who knows what the problem was.
Old Apr 25, 2011 | 08:31 AM
Doc brown's Avatar
Good to hear. If it comes back, and you have an '07 or newer, the hub is covered under the 100k drive train warranty. If not, and you can do your own work, I paid $118, including shipping, for my hub through Rock Auto.
Old Apr 25, 2011 | 12:44 PM
B1GP1MP1N's Avatar
Mine is an 06 with 60K. So no go on the warranty. How difficult was install?
Old Apr 25, 2011 | 02:20 PM
Doc brown's Avatar
If you can change your own rotors, then this isn't much harder. The hardest thing is the main shaft bolt. It's easiest to take off and on if you have an air gun. Then its just 3 additional bolts. Its all white metal so nothing really sticks so bad that its hard to get off. Once all the bolts are off, you'll have to nail it pretty hard from the back edges with a hammer. There is corrosion on the white metal where the hub slides in, that builds up and needs to be sanded off before putting the new one in. The whole thing took me about an hour, and that's taking my time.
Old Apr 25, 2011 | 02:49 PM
B1GP1MP1N's Avatar
Thanks for the Info Doc.... Hopefully it was just a fluke but it sounds like a repair I can do on my own if needed!
Old Apr 25, 2011 | 07:34 PM
BlackknighT's Avatar
If the light comes on once-it will come on again. Ask the dealer how much they would charge for pulling the codes & and estimate of the work. Let them know you may not be able to get it repaired right away due to low funds. It may be worth it to pay them to diagnose it based on their codes, and if it is something you can repair at least you only changed one part instead of throwing multiple parts & electronics at it. OR if you have them do the work when you get some cash they might credit the diagnosis money back towards the repair. Most reputable shops will do that. Good luck with whatever you choose.
purple people eater
Sep 17, 2016 01:07 PM
NxlKing2304
"How To" Tutorial Library
Apr 10, 2015 12:23 PM
venomlegionsHHR
Apr 11, 2012 04:42 PM
Kane2727
Mods - Exterior
Apr 2, 2012 10:46 AM
itschaboykenny
Feb 17, 2008 12:01 AM
