AC draining in passenger floor board 07
Old Apr 22, 2014 | 08:33 AM
Countrygrl55's Avatar
Hello other HHR drivers.
I am looking for a picture of where the drain hose will be located on the back of the front right tire. The car keeps filling up with water. I changed the cabin filter that was clogged but now car ac is draining inside car and making a mess.
Old Apr 22, 2014 | 09:19 AM
db/sb's Avatar
Welcome. Here's a post that describes it. I'm sure 843 won't mind me borrowing his post.
https://www.chevyhhr.net/forums/show...16&postcount=2
Old Apr 22, 2014 | 04:52 PM
A/C drains under the hood, sunroof drains behind tire.
Old Apr 22, 2014 | 06:32 PM
Welcome to the site!!
Old Apr 23, 2014 | 01:38 AM
Lucky's Avatar
Welcome to the site You may have to bend this shield to be able to see and check the drain.
Old Apr 25, 2014 | 03:14 PM
babeba67's Avatar
i have a picture of the condensate drain tube in my profile picture. Pretty sure my heater core is leaking. You can see the drain tube if you look from the drivers side with a flashlight and look towards the passenger side on the firewall. The picture I took is from underneath the car however.
Old Apr 25, 2014 | 03:56 PM
db/sb's Avatar
In your other thread you said that you're losing coolant. From what I recall, we had determined that your problem was with the heater core or the hoses/connections to it. This thread is about evaporator condensate. Two different problems. But they will both leak from the same area since it the path of least resistance (as long as it's not clogged). The poster that started this one apparently never came back.....
Old Aug 23, 2014 | 08:07 AM
lightbubhereld's Avatar
chev hhr 2007 ac drain
Hi ,water running down on passengers side of floor .Where do I find drain hose and how do i unclog it?
Old Aug 23, 2014 | 08:17 AM
Welcome to the site.
Did you read this whole thread ? There is a link in post #2. Pretty much all the info needed is covered.
If you need any more info, try the Search function. There have been several different threads about clogged AC drains.
Old Aug 23, 2014 | 09:58 AM
Not to mention the photo in post #5.
