Ac only on passenger side
Old Aug 27, 2010 | 10:14 AM
mind's Avatar
07 hhr - it only blows cold on the far right vent.
the far left vent blows hot and each vent blows a little cooler until you get to the far right vent which blows cold.
I wanted to see if anyone has dealt with this before i start pulling the dash apart.
Blower works fine and there in no trash in the filter area.
thanks,
tony
Old Aug 27, 2010 | 07:41 PM
ChevyMgr's Avatar
Haven't heard of this ever on an HHR. Seen it a lot on systems that have dual zones for driver and passenger.
Old Aug 27, 2010 | 11:33 PM
mind's Avatar
it turned out it was a little low on freon. i don't really understand it, but it's working now!
Old Aug 28, 2010 | 03:57 PM
Lucky's Avatar
sounds like a weired problem. thanks for sharing your fix somone my use your info to fix there problem
Old Aug 28, 2010 | 04:23 PM
Don06's Avatar
Not too strange. Freon enters the evaporator from one side and expands(evaporates). If the system isn't full, the expanding freon doesn't fill the evaporator so it only cools part of it. The air that goes through the cold part is the air that comes out the right side.
Old Aug 28, 2010 | 06:28 PM
Old Lar's Avatar
I traded my 99 Buick in for the HHR after fixing the dual zone AC issues several times.
trp313
Jun 22, 2017 07:53 AM
Marcruger
Jul 29, 2009 07:31 PM
dbarberaz
Sep 1, 2006 10:59 AM
