My 2007 HHR
Old 01-03-2024, 06:06 PM
Deborah's Avatar
My 2007 HHR
Will not turn over or start and has no power even for lights and key. It is making a constant clicking in the fuse box under hood and under radio. It feels like fuse or relay#68 is clicking. What can I do?
Deborah is offline
Old 01-03-2024, 06:32 PM
Dead battery ?
Tried to jump start it ? Charge the battery ? Check the voltage ?
firemangeorge is offline
Old 01-03-2024, 10:07 PM
Hi Deb, to the forums!
Might be yet another case of fuse block bolts not tight enough. They need to be really tight. Inside the underhood fuse block.
Also check the battery cable terminals, for tightness and cleanliness. At the battery, on the side of the underhood fuse block, at the starter, and on the alternator. The terminal clamps at the battery have also been known to crack. Remove the NEGATIVE battery terminal clamp, then remove, clean, and reattach all the others, finishing with the aforementioned negative battery terminal clamp. While the battery is disconnected, you could take it to the auto parts store for a free load test.
RJ_RS_SS_350 is offline
Old 01-04-2024, 11:36 AM
Technical Moderator
My bet is that you have no idea where the battery is or that they wear out with time.
The battery is in the rear under the tray that covers the spare tire. The battery that came in the car is a 8 year battery, most replacement batteries are good for either 3 or 5 years.
donbrew is offline
Eileenandtm@gmail.com
01-17-2023 07:18 AM
LadyBee
07-10-2022 01:15 PM
kornellred
07-14-2021 06:59 PM
pstar
07-06-2010 08:25 PM
Smoke Wagon
03-13-2009 10:30 PM
Quick Reply: My 2007 HHR
