Research Topic: Airbox replacement mounting grommets
#52
OK donbrew. Good idea when you can find them.
You could be right, but the general says all of the other rubber/nitrile parts are oem GM quality. So you should buy their parts. They will last longer.
I went to OEMCATS.com and they say 19178771 is interchangeable with or replaced by 12563914 and or 15809014. It/they is/are a 1.00 inch diameter grommet.
Buy GM 19177871 Insulator, genuine OEM part
15809014
12591715; 32mm dia
25346092; air cleaner front, interchangeable with next one
25176248; same as above
88967324;
22676978;
22693712; 1.60 dia
25920906; HHR 2008-2010 probably for SS
15776158
25099300
Now I'm really confused. It seems the further I go the behinder I get.
Too tired to continue.
To be continued later
DAVE
15809014
12591715; 32mm dia
88967324;
22676978;
22693712; 1.60 dia
15776158
25099300
DAVE
#55
I've received a lot of help from this community so with this I try to pay some of it back. All credit goes to Eli at Keyes Chevy in Van Nuys, CA.
Rear insulator part#: 19177871
I hope this helps some people! The insulator on the right is from my car (2007 HHR 2.4 manual).
#60
I have a 2009 LT2 2.4L. I just finished replacing the intake solenoid and thought I may have to change out the insulators on the airbox. I think I read this thread 3 times to try to figure out what parts to order to have on hand.
For the back I got GM # 19177871. They matched exactly the ones on the car and had the same number molded in the rubber.
The front insulator had disintegrated so there was nothing to compare. I had ordered GM # 12563914 and it worked fine.
