Alignment needed after LCA bushings replacement?
I just replaced LCA with new bushings installed. The last alignment was done about a year ago when I replaced LCAs. Do I need a realignment after this?
Justtires, after doing free alignment check, tells me that I do. Often times I have doubts about those free alignment checks. No matter what, the always tell you that you need an alignment.
Is tire wear the best way to judge whether you need an alignment?
If you had an alignment with the old worn LCA’s and this worn rear bushings , then you’re gonna need another alignment to put it back to basics, now really the only adjustment would be toe as the camber and caster are set pretty darn close to dead on with the new LCA’s
Educate me on this. From what I've read the only thing you can adjust is toe. To do a camber adjustment you have to have this:
https://www.moog-suspension-parts.com/moog-k9757
Setting caster is another ball game.
The only way I know with a strut is to have a slotted upper mounting area for the strut to go back and forward.
Remember, camber is the tilt out or in of the tire at the top and caster is the rake of the spindle forward or back.
As far as the toe setting, both too much and too little will cause tire wear. If you run your hand over the tread you will feel a feathered edge if not set correct. Too much in will make the car harder to steer and too much out will make the car wander or dart from side to side.
Camber too can cause the tire to wear. Inside or outside edge of the tire.
When I put on my lowering springs, I bought a set of Moog camber bolts similar to those. When we put it on the alignment rack the camber was still within specs so the camber bolts were not needed.
What are the other brands that give you different camber adjustment angles?
Thanks
There are hundreds of brands of camber bolts. Most I've seen give 3 1/2 degree total adjustment. I have seen them from $5-$30 they all appear to be the same to me; a bolt with an offset adapter and a nut.
Warning: after installed you will need alignment regularly. Good idea to have new struts when installed to save the extra alignment. They don't come with instructions, so get an experienced person to install them.
I can see new struts if the mounting holes to the spindles is egg shaped, for one reason or another.
And of coarse the bolts don't come with instructions. There meant to be installed by a qualified front end shop.
I say all this because I've done many alignments in my life.
Here's a video:
