Another P0014 problem....
This site is usually pretty good https://www.obd-codes.com/p0017
Why think "camshaft sensor"? It is doing its job along with the crankshaft sensor.
P0014 is "exhaust camshaft position system performance"
P0017 is "crankshaft position - exhaust camshaft position correlation"
Put those 2 together. Kind of makes sense that either the exhaust VVT valve or the exhaust phaser is at fault.
I would go for the easiest and cheapest first; new exhaust VVT valve.
If you still have the cover off, post a photo of the chain , looking down the front part of the area where the front guide is, do you see any signs of a broken guide? Upper guide bolt missing?
Saying the chain is fine doesn’t really help. Since you have a code for a possible skipped tooth, did you verify that the timing marks are still in place ?
Also. If you didn’t change the oil when you replaced the solenoids that’s probably why that code returned back then.
Solenoid replacement should always include an oil and filter change no matter how old the oil is.
