Atlantic City Depressed Way HHR SS Transmission Problem
Old 03-18-2019, 04:23 PM
Bucket of Hot's Avatar
Unhappy Atlantic City Depressed Way HHR SS Transmission Problem
My 2009 Chevy HHR SS with "at the time" less then 90,000 miles on it, blew out 5th gear on the Atlantic City Expressway. Leading up to the transmissions catastrophic failure, it had popped out of 5th gear a few times minutes before hand. Chevy's warranty would not cover it "of course". So I found a mechanic that replaced the transmission with a used one. It was fine for a few months but now that transmission is popping out of 5th gear too! My mechanic told me that he rebuilt 5th gear on that transmission and was not sure what the problem could be. Now he wants to replace the linkage as that wasn't replaced when the transmission was installed. My question is could that really be the problem? Also is there any GM mechanics that aren't dealerships around me in South Jersey that could help? I love the car and own it outright and would hate to trash it due to this issue.
Bucket of Hot is offline
Old 03-18-2019, 04:45 PM
Cat Man HHR's Avatar
Let's start. You had a used trans put in. How did this mechanic know to replace 5th gear before it was installed ? 5th gear is a gear also.
Sorry I can't find an exploded view of this trans. Worn clutch dogs for the synchro sliders can make a trans pop out of gear in other units.
Maybe someone on this forum could dig up pictures. That would help.
Cat Man HHR is offline
Old 03-18-2019, 07:20 PM
There is no real linkage. Just 2 shift cables between the shifter and transmission.
firemangeorge is offline
Old 03-18-2019, 08:55 PM
They look similar to these cables
Oldblue is offline
Old 03-18-2019, 09:53 PM
I agree that the clutch dogs are probably the culprit but could it be a bent bracket or worn cables? He seems convinced, but I'm thinking it's more of my money being wasted. Also, if it is the clutch dog gear is "chewed up" haha, does the transmission have to be pulled to replace the 5th gear clutch dog?
Old 03-19-2019, 08:18 AM
DrLoch's Avatar
Yes
DrLoch is offline
Old 03-19-2019, 09:05 AM
extanker's Avatar
if the repair was not too long ago maybe the shop will stand behind it or give you a break
extanker is offline
SIHHR
North East
94
01-09-2007 02:53 PM
CheckSando
North East
24
06-20-2006 10:16 PM
SIHHR
Mid East
05-10-2006 10:22 PM
Quick Reply: Atlantic City Depressed Way HHR SS Transmission Problem
