Blower motor not getting power 2007
Replaced bm3 fuse, it was blown and other fuses good. replaced resister and blower relay. Still no power to resister nor blower. Not sure if it is the blower as no power. Maybe the switch, etc. Any others have similar problem.
No need to start another thread about the same problem.
To answer your question. Get out the multi-meter and start checking. Recheck the fuses and relays(make sure there is power TO the relay). Then check the bm for voltage. None? Check the fan switch on the dash. |
x2 - and as already suggested in the original thread.
this one is closed. |
