Brake lights only work when ignition on
My 2008 LT brake lights are only working when the ignition is turned on. I have scoured the posts and have not seen a conclusion.
Is this common? I recall the lights working all time?
I'm trying to avoid a trip to the mechanic and appreciate the help.
Scarfoot
Scarfoot
My 2010's brake lights only work with the ignition on. This is normal because the brake light system works through the BCM I believe.
It could be different on some of the earlier models. Not exactly sure if there was a change to the brake electrical system during the 2006-2011 models.
xnigma
05-24-2018 08:33 AM
myers1wa
11-10-2013 04:24 PM
volcycle
10-12-2008 08:34 PM
