Butyl Patch
Hey, so I just found out that the "butyl Patch" under my cowl is completely disintegrated. For now I've put in a waterproof cloth cut to size over the place but it doesn't look like it'll hold. Is there a place where I can buy a new one (what's it called) or does GM not make that specific part? I saw the handful of DIYs on YouTube and just wanted to check before I do any.
Regards, Allen P |
Make your own out of something stronger, like a piece of sheet metal. Then seal it in place with your choice of a quality sealant.
It will then last the life of the car. |
That's what I did.
No leaks, no fuss The butyl patch was an after build "oops" when it was discovered that water could/would get into the fan assembly. |
When I had my HHR, I replaced the patch with aluminum roof flashing, of the appropriate size, from Home Depot. Lasted the 8 years I had the car and 2 or 3 for the next owner, who was a friend. re Don't exactly remember what I used to seal it, but I believe it was some type of butyl. I believe I even posted a picture if it is still around.
Originally Posted by Snoopy
(Post 911812)
I cut it to size and used the 4 minute epoxy glue to seal it in. https://cimg5.ibsrv.net/gimg/www.che...65edb61cb3.jpg https://cimg9.ibsrv.net/gimg/www.che...f0aa1bb64a.jpg https://cimg4.ibsrv.net/gimg/www.che...80b835616e.jpg Appreciate the help, Allen |
Job well done!
| All times are GMT -5. The time now is 09:09 AM. |
