A/C cycling between warm and cold air.
Old 05-27-2017, 08:59 AM
OK. So you have a little more knowledge about cars than you stated in your 1st post.
That being the case, I would think either a blend door problem or the inline AC pressure switch.
firemangeorge is offline
Old 05-27-2017, 09:37 AM
Technical Moderator
Does the compressor turn on and off? Make noise?
Pressure switch, clutch, button, loose wires.
donbrew is offline
Old 05-27-2017, 10:54 AM
Steve Allen Walls Jr.'s Avatar
Im gonna do some looking into the pressure switch. See what I can find.
Gonna check that switch out. See what's up. Thanks.
Steve Allen Walls Jr. is offline
JamesCardoza
08-16-2013 02:19 PM
BJarvis
11-04-2011 02:48 PM
GreyGhost07
06-06-2010 06:10 PM
phcoy
02-09-2010 12:05 AM
hookupny
10-24-2006 09:57 AM
Quick Reply: A/C cycling between warm and cold air.
