A/C Stopped working and Lots of codes
Old Jun 24, 2016 | 08:32 PM
tjsaudio's Avatar
Ok I was driving my car and Turned off the A/C with the button when I went to turn up the fan. So I bumped the bumped the button to turn it back on. no A/C. the clutch does not engage. I checked the connection and unhooked it and re clipped it. that looked good. so I hooked the the Snap On Solus and a ton of codes came up. p0053,p0054,p0116,p0128,p0131,p0134,p0137,p0138,p0 13a,p013b,p013e,p013f,p0325,p0420 I stopped writing them down at that point there was more. The Snap on tells ya the codes and what they are. so I noticed my Electric cooling fan on the radiator was not coming on and the temp was at 219ºF so I did a Function test and manually turned it on and that worked. But only when i do it that way. I manually turned on the A/C clutch and nothing. so any Ideas?
Old Jun 24, 2016 | 10:03 PM
Certain codes will disable the AC.
As far as numerous codes pulled. It may be an electrical issue. Under hood fuse box connection problems are a known issue in the HHR.
A weak or bad battery can also trigger wacky multiple codes.
As far as the cooling fan not operating at those temps, not sure there. Especially since you state that you can turn it on with your scan tool.
Fwiw. Really would help to post the year, model, mileage and any repair history.
Old Jun 25, 2016 | 12:43 AM
As George pointed out, your model year, engine size, and the mileage on your HHR will be a tremendous help.
With the multiple codes, step #1 is to check the underhood fuse box, see this thread below...
https://www.chevyhhr.net/forums/how-...ers-check-522/
A cooling fan not engaging could be related to loose fuses/relays or seperated fuse box halves as explained in the linked thread above.
Or your engine coolant temperature sensor could be going bad, either way, it's an issue which requires prompt investigation and correction.
Ecotec engines are very intolerant of overheating in any way, shape, or form.
219° is mild overheating, but once you go over 230°, cylinder head and head gasket failures are a given.
Get it to 240°, and you've bought yourself an engine.
Old Jun 25, 2016 | 07:51 AM
You have a blown fuse, is my bet.
check the fuse underhood #33.
Before you test a new fuse, find the wire that has chafed on something. My guess is the wires to the O2 sensors laying on the exhaust.
The A/C won't work because of the codes. I don't know how futzing with the switches would cause the codes.
Old Jun 25, 2016 | 08:35 AM
tjsaudio's Avatar
I'm sorry forgot to do that. Thanks. 2009 HHR Panel LS 2.2l just about 190,000 miles. not much of a repair history at all. Engine has been great. We put 164,973 miles on it in about 3.5 yrs and let it sit for just over a year inside the shop. Then I bought it for $2500 no rust and at the time mech sound. Just put a new battery in it and off I went.
Old Jun 25, 2016 | 09:19 AM
Mike. I'm going to have to disagree with your statement above. If the OP can turn on the cooling fan with his scanner, then I would think that the fan wiring was making good contact in the fuse box.
Now granted. OBD, computers and modern wiring systems,,,yes, something could be loose and affecting other things. Just don't think it's going to be the specific cooling fan relay or fuse that's the problem.
Old Jun 25, 2016 | 09:34 AM
The P0128 code would shut down the A/C
Old Jun 25, 2016 | 01:28 PM
Fuse #33 feeds the O2 sensors, the EVAP purge valve, the MAF/IAT. All of those codes are related to those items.
Add to look at relay #26, since it feeds fuse #33 and the A/C clutch relay, the ECM fuse, INJ IGN MOD fuse.
Old Jun 25, 2016 | 09:39 PM
tjsaudio's Avatar
Did the fuse thing and same problem. And tested all the fuses and they tested good. Even switched out the resistors. The ECT is working fine to what I can see. I hooked a new one up just to see what would happen and still no A/C. I already checked the A/C relay and that works. But I noticed that it kinda gets hotter than the others. I don't know what to think at this point. Is there 2 ECT on this 2.2L?
Old Jun 25, 2016 | 10:19 PM
Well I'm confused by some of your descriptions.
Resistors ?
ECT ?
As stated before, some codes will disable the AC. Unless you clear that code, (as Oldblue said, P0128 is one that disables AC function),the AC compressor will not engage.
