Can’t get launch control to turn on
Just bought an 09 hhr ss with 137xxx miles, runs pretty solid but the abs light is on the maf is brand new but isn’t functioning properly and I Can’t get launch control to even turn on...is this because some of the tpms need replacing? I got a good price on it and I knew there’d be some work involved just don’t know where to start. Any help would be appreciated
Have you you pulled any codes?
Why do you say the MAF isn't functioning correctly? Start with these first |
Welcome to the site, yes codes please
The reason is the ABS light. Fix it launch will be fixed.
Originally Posted by donbrew
(Post 867110)
Remote Start won't work if there are any codes, so it stands to reason. |
I don’t have any codes I’m bringing it to someone tomorrow evening and he is going to pull codes and I will get them to you guys thanks for the help....I was told it’s the tpms that had the abs light on but I’m not sure if that’s true the brakes feel like they don’t work until the end of the peddle
Originally Posted by DrLoch
(Post 867103)
MAF or MAP?
Maybe plug the MAF in and see if the launch control will come on.
Honestly though. If you're running the car with the MAF unplugged, I'll bet the ECM and PCM are going nuts. There may be numerous trouble codes present and other systems rendered inoperative. |
(Post 867205)
