Car surging after replacement of Camshaft Position Actuator Solenoids
Hi everyone,
I replaced Camshaft Position Actuator Solenoids yesterday, and the car is surging sometimes after I start driving it. After driving it for a while longer, the surge disappears and it runs fine. I did now have that problem before when I replace Camshaft Position Actuator Solenoids two years ago. Is there a break in period for these?
Thanks.
Thanks.
I replaced my intake and exhaust solenoids late winter and experienced a similar same result. My CEL codes stayed on and still indicated the same intake issue. I replaced the cheap Chinese intake solenoid I had installed with an AC Delco and the CEL went away and the problem went away. Runs perfect now.
You're right. I should have just said they were "off brand" parts I found on Amazon. Had great reviews too. They probably just have a slightly higher failure rate than a brand name or OEM part. It was actually my mechanic who suggested I get the genuine part or at least a reliable brand like Borg Warner or AC Delco. He said he'd do it for me, but since I had done the labor once already I should probably try just replacing the intake since the cheap exhaust one appeared to be working.
