Chevy HHR Network
-   -   Car surging after replacement of Camshaft Position Actuator Solenoids (https://www.chevyhhr.net/forums/problems-service-repairs-42/car-surging-after-replacement-camshaft-position-actuator-solenoids-61966/)
slonny Jul 5, 2019 12:36 PM
Hi everyone,
I replaced Camshaft Position Actuator Solenoids yesterday, and the car is surging sometimes after I start driving it. After driving it for a while longer, the surge disappears and it runs fine. I did now have that problem before when I replace Camshaft Position Actuator Solenoids two years ago. Is there a break in period for these?
Thanks.
RJ_RS_SS_350 Jul 5, 2019 01:26 PM
No break in period, check for codes. Make sure you reconnected the MAF sensor.
Oldblue Jul 5, 2019 07:47 PM
Yes check your work, all connections.
joepepsi Jul 8, 2019 12:27 PM
I replaced my intake and exhaust solenoids late winter and experienced a similar same result. My CEL codes stayed on and still indicated the same intake issue. I replaced the cheap Chinese intake solenoid I had installed with an AC Delco and the CEL went away and the problem went away. Runs perfect now.
Oldblue Jul 8, 2019 05:02 PM
Thanks for clarifying and confirming you get what you pay for.
Now don’t start , I know everything these days are from China , but I would hope to set specifications.
whopper Jul 9, 2019 12:55 AM
slonny - can you give us some details on which solenoids you purchased? ie: a link to the info
joepepsi Jul 9, 2019 09:40 AM
You're right. I should have just said they were "off brand" parts I found on Amazon. Had great reviews too. They probably just have a slightly higher failure rate than a brand name or OEM part. It was actually my mechanic who suggested I get the genuine part or at least a reliable brand like Borg Warner or AC Delco. He said he'd do it for me, but since I had done the labor once already I should probably try just replacing the intake since the cheap exhaust one appeared to be working.
