Car won’t start
Old Feb 16, 2020 | 10:53 AM
Marc Guay's Avatar
Originally Posted by donbrew
Use a VOM to check the battery voltage. A 50% discharged battery is about 12.4 volts, at 70F
Alrighty. Charged all night. Same one click from the solenoid. I’m gonna have my buddy come over later and try his battery.
got it bumped again this morning, the wipers are going really slow when it’s running. All clues 🙂
I’ll keep posting until I get an answer. Thank you al again for your help.
Old Feb 16, 2020 | 11:17 AM
Cat Man HHR's Avatar
Wipers running slow to me means the charging system isn't working correctly and you are running off just battery voltage that is almost dead.
What do you mean "got it bumped again this morning" ? You got it started again ?
Are you using your friends battery now ?
Old Feb 16, 2020 | 11:26 AM
Bumped, as in he pushed it , and put it in gear and released the clutch, it’s a manual transmission as he said earlier.
Old Feb 16, 2020 | 12:05 PM
Marc Guay's Avatar
Yes. Sorry, this is what I did to get it going.
came home, took the negative right off the battery, still ran so I think the battery is the culprit as the battery light never came on all drive. About an hours worth of driving
Old Feb 16, 2020 | 12:07 PM
Marc Guay's Avatar
Dead cell in the new uncharged battery, very possible.
Wrong battery for HHR , possibly, what is the CCA rating?
got the new battery back in August. 600 cca 100 ex 60 ah
delco with the vent line attached
Old Feb 16, 2020 | 12:08 PM
Casa Del Gatos's Avatar
A bad battery is a really common cause for all kinds of maladies in these cars. Every one I have bought needed a new one pretty soon.
Old Feb 16, 2020 | 12:35 PM
I guess that's a Canadian thing.
Old Feb 16, 2020 | 12:36 PM
We always had to bump start our sprint cars in either side of the border. Not a Canadian thing at all.
Old Feb 16, 2020 | 12:40 PM
Blue it was meant to be a joke.
When I helped with Modifieds we would always push start it if the starter gave up the ghost.
Always pushed started street cars that had a clutch also.
Old Feb 16, 2020 | 01:13 PM
If you mean you disconnected the negative battery cable while the engine was running............DON'T DO THAT..
That's a good way to mess up some of the electronics on a modern day, computer controlled car. That old school, shade tree thing of disconnecting the battery might have worked back in the 1960's. Not on today's car's.
