Catalytic converter life cycle?
Old Jan 7, 2018 | 10:17 AM
Those two codes have a common denominator of air leaking near the second O2 sensor.
It could be a clogged catalytic converter.
I’ve gone through the replace one piece at a time, so, if you can get under your HHR ( safely on jack stands) take a 7/8 inch open end wrench and tighten the rear O2 sensor.
If that fails, then you could replace the rear , then the front, then the catalytic converter down pipe, either one at a time , or in one fell swoop.
I wish I knew then what I know now, when I was chasing a P0420 code a year ago.
I would have simply ordered all three parts and be done with it.
Old Jan 7, 2018 | 10:19 AM
One of the ways too much oxygen can get into the system is a cracked flex pipe or a hole in the pipe. Is it cracked or rusted through?
Old Jan 8, 2018 | 09:57 AM
aradmahogany's Avatar
My Florida born and raised HHR still has all stock exhaust components from header to the tip of the muffler, 220,000 miles and counting.
whopper
Maintenance and Upkeep
0
Apr 29, 2011 02:08 PM
LolaIsMyHHR
Mar 29, 2011 10:37 PM
DjLBM
Feb 22, 2011 01:49 PM
themoodman
Oct 29, 2010 11:50 AM
donbrew
Dec 25, 2009 02:55 PM
