Changed front hubs, new wheel issue.
So, about 4 months ago I bought a 2009 Chevy HHR LT 2.4 with 156000 for $1700. There was a very faint hum when driving but as this was the first HHR I've owned, I didn't think anything of it, maybe it was tire noise. As the time went on, the noise grew into a deafening roar that could be felt in the steering wheel, gas pedal and seat. I am somewhat mechanically inclined and was able to narrow it down to one of the front wheel hubs. As I researched how to find which it was, ultimately came to the conclusion to change both, considering the age and milage. I did so, with practically no trouble at all. The most trouble I ran into was getting jack stands. I even replaced the axle nuts for both. I ensured hub bolts we torqued to 85ft.lbs. and the axle nut was 155ft.lbs.
I took the car for a test drive and the roar was now a whisper. But, a different issue not noticed before arose. Now there is a small wobble or shaking in the front end, I believe at the drivers side wheel area. Best I can tell it doesn't start until around 40mph. And it isn't constant. It'll wobble/shake for a few seconds then fade out and after about the same few seconds it fades back in, so on and so on. I live and work in a small town with highest speed limit reaching 45. The shaking reminds me of an unbalanced tire but it isn't constant, it fades in and out every few seconds, consistently. Since I bought it I have only had to repair both rear shocks. I don't know if the problem was always there and didn't notice due to wheel hubs being bad or not but I love this car and want to keep it running. Please help. |
Do this:
But, I am going to do the little test he performed by pushing backwards on the wheel to see if I have any try results because frankly, when I noticed the issue I wasn't looking for the other signs. So when I get off work this evening I am going to try the moving tests and then the other when I get home. I will update with results after. If you or anyone else has another suggesting, I'll hear any that y'all have to give. Thank you for the suggestion, I am definitely going to follow this one. |
DJ , welcome to the site, X2, it’s the LCA’s! Change both, get aluminum one’s not the stamped steel, Moog or AC Delco.
https://www.rockauto.com/en/catalog/...trol+arm,10401 We are offered a discount from RockAuto https://www.chevyhhr.net/forums/www....ad.php?t=61707 |
I raised the car and put it on jack stands. I removed the tires and on the inside wall of the passenger tire is a lump about the size of a golf ball sticking out about 2 inches from the tread. Could that be causing the problem? I am getting that tire replaced either way tomorrow I am just wondering before I drop$200 on the LCA's.
A bit of testing will save you angst.
Change bulged tire, test drive, if noise is gone, don’t order LCA’s.
If noise remains, order LCA’s |
I know doing the tests helps eliminate a lot of headache. I work 6 days a week and
all day and so on Sundays when I get all my honey do list and other housework done, I am trying to squeeze that in too. I have 8yr old twin girls who want me to themselves on Sundays and they aren't afraid to get down in the dirt with me to work, I just don't like them around raised cars (I've had my right ring finger ripped off from a falling jack). So I'm trying to get as much information as possible how I can. I searched all over the internet and this forum before I ultimately created this thread to ask about it. I really appreciate everyone's information. I have been thinking about getting the most likely to fail components of the front end replaced, preventative maintenance, and get it over with. I can do all the work myself except for anything that requires pressing bearings. Would that just be better? And if so, which components should I replace? I'm trying to only do the ones most likely to fail and dangerously fail. I will look through the forum again to get idea of the ones most mentioned failing by members. Thanks again |
You can just remove the rear lca bushing and press new ones in with a ball joint clamp press , most parts palaces rent them .
https://www.chevyhhr.net/forums/www....ad.php?t=39002 |
OK, pay for unneeded repairs if you can't spare the minute it takes to attempt rolling a tire. Your time is awfully expensive. But, you have the time and money to throw parts at the car.
I don't get it, maybe it makes sense to you. |
